Konica minolta 363 driver issue?
  • sholem74
    • Feb 2018
    • 3
    [Misc] Konica minolta 363 driver issue?
    Hi
    We have recently installed a bizhub 363 in the library of a high school, there are abiut 30 computers printing to the copier, the users log into the active directory and the printer is deployed to the desktop.
    The client complains that the print spooler hangs randomly and that the only way to get pruning again is to stop the spooler, delete the waiting jobs and restart the spooler again.
    I've tried both the pcl and postscript drivers. But the problem remains. I'd try a generic driver to see if he problem is solved, b I t the client is using job accounting with user codes so that won't help.
    Has anyone seen a problem like this?
    Thanks and have a good one
  • rrrohan
    • Sep 2011
    • 1977
    Re: Konica minolta 363 driver issue?
    so printer is installed on a server?
    and when you say they restart the print spooler do you mean on local pc or server?
    and when it locks up does it effect just the one pc or all of them?
    id also check if any driver versions are out of date
    • sholem74
      • Feb 2018
      • 3
      • lilleputte
        • Jan 2013
        • 154
        This might be helpful,
        Läs mer om uppdatering KB4517211, inklusive förbättringar och korrigeringar, samt om kända fel och om hur uppdateringen hämtas.
        Check known issues in this update
