B958 "Please Wait"
  • rrrohan
    • Sep 2011
    • 1977
    B958 "Please Wait"
    Model: B958
    Firmware: GC3-R9 Function version 4.1
    Customer scans a lot and every so often this message appears "Please Wait"
    (sorry about orientation)
    It eventually goes away after around 1 minute. Cant do anything until this vanishes.
    Scans are to a locally hosted email server.
    Issue does not effect the C554e or C558 in same network.
    First time I have seen this issue so not sure whats causing it.
    It also never has done it for myself and I tested it for ages so not sure if its possible customer doing something odd.
    Tried MFP, HDD. Still same issue.
  • Bix
    • Apr 2018
    • 1421
    Re: B958 "Please Wait"
    Hi, have you installed LK-114?
    In the 4.2 G00-W5 firmware the problem could be solved.
    • rrrohan
      • Sep 2011
      • 1977
      Nah no server-less pull printing
      Just returned and now touch screen locks up with no error
      • tsbservice
        Field tech
        • 7981
        Any errors logged in machine history?
        You also can try to Update Operation Panel CPU Firmware.
        • rrrohan
          • Sep 2011
          • 1977
          Didn't know know CPU had its own firmware.
          I will attempt to find it. Tomorrow
          • gere1
            • Oct 2018
            • 20
            Hello
            I have been given some case of locked screens
            I had a problem with the network
            disabling SSDP does not repeat the problem
            Of course, it is in series 8, it has never happened to me
            in 4 yes
            • tsbservice
              Field tech
              • 7981
              Originally posted by gere1
              Hello
              in 4 yes
              That sounds interesting...I guess it's part of my never-ending learning curve
              Of topic.
              Could you be more specific about cases when turning off SSDP cures strange MFP behavior.
              • rrrohan
                • Sep 2011
                • 1977
                ok disabled SSDP. had a call about 1 hour later. machine has locked up again.
                The problem is the only errors i get dont show up in manual
                Support wants me to update to G00-X4 Function 4.2 So trying that now
                • Bix
                  • Apr 2018
                  • 1421
                  From your Management List I deduce that the machine has rebooted several times.
                  As I suggested, it's possible that the firmware update will solve the problem for you.
                  • tsbservice
                    Field tech
                    • 7981
                    Run full diagnostics.
                    • rrrohan
                      • Sep 2011
                      • 1977
                      the reboots are manully performed by customer to get it back online
                      but so far firmware is seeming to be going go so far
                      the strange thing is my supervisor said he couldnt find any firmware later than GC3-R9 on knova.a i did think it was odd too since GC3-R9 is like 2 years old now
                      • tsbservice
                        Field tech
                        • 7981
                        Your supervisor is mistaken, there are many special FWs and I think 3 base FW versions newer than yours.
                        I still will run full diagnostics though, it takes like 5 min.
                        • rrrohan
                          • Sep 2011
                          • 1977
                          I've never had anything useful come from running diagnostics so kind of forgot about it. i can try it if i hear back on monday.
                          • rrrohan
                            • Sep 2011
                            • 1977
                            KM advised me to install G00-X4 and I did that over 3 working days ago and havent had a call back yet. fingers crossed it is resolved now
