CS650 and color change issue
  • Techead42
    • Mar 2008
    • 32
    We've been struggling with a CS650 color change issue...customer runs a print job with gray background & background progressively fills with magenta till the original color is no longer recognizable. Internal test prints look fine (#53, each color, about 40%). Any thoughts?
  • knightfall
    • Jul 2006
    • 633
    do you have the latest firmware installed? 3 color gray are usually the hardest to maintain consistent you may want to see if the customer is willing to use black to make gray instead of 3 colors.
    Get your facts first, and then you can distort them as much as you please.
    • Setright
      FSS / SPM
      • Nov 2008
      • 247
      • random
        Originally posted by Setright
        Have you set the gray balance using the manual gamma offset adjustment in the quality part of the service menu?
        This is pretty critical and often overlooked so I suggest you go thru this procedure with a fine tooth comb. Unlike the c500 the offset adjustments do have an effect on printing.
