I am having trouble calibrating an IC-304 using a densitometer. i always get the following message "measured density is below minimum expected values".
i have re-calibrated my C6500, i have swapped out the densitometer, the creo is up to date as per firmware and patches, i have taken the machine back to factory settings and re-calibrated, i have tried to increase the denisty, i checked DPSW 23 Bit 5 which is at 0 to enable, i am running out of ideas. does anyone have any? the customer has had this machine for over a year and has only started having this trouble recently. the machine only has about 370K on it.
