Bizhub will start printing slowly after a few days
  • Bix
    • Apr 2018
    • 1421
    Hello,
    I have a strange problem. I have a Bizhub C458 with FW G00-W4.
    The printer receives native files from SAP and after about 10 days, it begins to print slowly. There do not seem to be problems if you print outside of the management software.
    In the printer settings the priority has already been set for the production, lowered network time-out and I have deactivated spool Print jobs On HDD before RIP.
    The only solution to resume printing correctly is to turn it off and then on again. Could it be a FW problem? Any experience or suggestions?
  • qbert69
    • Mar 2013
    • 1152
    Re: Bizhub will start printing slowly after a few days
    Originally posted by Bix
    Hello,
    What do you mean "receive native files from SAP"?...What is SAP?[emoji848]
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • Bix
      • Apr 2018
      • 1421
      SAP is a multinational company that produces management software
      • qbert69
        • Mar 2013
        • 1152
        Based on that info, it sounds like you might need to contact SAP! Perhaps it is a data cache that is not being purged or cleared properly and thus causing slow processing or maybe somewhere the network connection is half duplex instead of full duplex or perhaps even the data stream is in a format that requires extra processing?![emoji848] I'm stumped!...but you did say that when the management software is removed from the equation the machine works just fine?![emoji848] Definitely sounds like something is glomming up somewhere!!![emoji2955]
        • tsbservice
          Field tech
          • 8005
          I'm afraid you will need to dig deep into this.
          • B0265
            • Jan 2007
            • 718
            I think this procedure was implemented to solve another problem, but it might be worth to try.
            Procedure of Setting Automatic Reboot every morning
            This function makes MFP reboot automatically at AM 4:00 (default) every day.
            The conditions of reboot function and procedure are described below.
            - Condition of reboot function
            Condition 1:
            Software Switch No.104 bit-0 is set.
            Vender serial number is set as one of following numbers.
            [10] or [11] or [12]
            - 10: MFP reboots at AM 4:00
            - 11: MFP reboots at AM 4:15
            - 12: MFP reboots at AM 4:30
            Condition 2:
            Under the Condition 1 is satisfied, MFP reboots at the specified time unless it is printing, receiving fax or in sub power off mode. If the MFP is printing or receiving fax, it retries to reboot after every 30 minutes for two times. The MFP does not reboot after 1 hour.
            - Procedure
            • tsbservice
              Field tech
              • 8005
              Condition 1:
              Condition 2:
              - Procedure
              Interesting and very clever solution in this case, good info.
              On a side note, do you know on what models this work?
              • B0265
                • Jan 2007
                • 718
                This is the information I have found:
                Model FW version
                bizhub C754/C654 GC1-68 or later.
                bizhub C554/C454/C364/C284/224 GC1-68 or later.
                bizhub 754/654 All version
                bizhub C754e/C654e All version
                bizhub C554e/C454e/ C364e/C284e/224e All version
                bizhub 754e/654e All version
                bizhub 554e/454e/364e/284e/224e All version
                bizhub 287/227 All version
                bizhub C658/C558/C458/C368/C308/C258 All version
                bizhub C287/C227 All version
                bizhub 758 All version
                bizhub 558/458/368/308 All version
                (ID-No. PSCSES_1900148EN / TABT1900148EN)
                • tsbservice
                  Field tech
                  • 8005
                  Model FW version
                  Anyway to clear a bit your PM Folders?
                  • Bix
                    • Apr 2018
                    • 1421
                    The solution is concerned. Weekly timer doesn't do something like that? Also is it possible to change the time?
                    Thanks!
                    • B0265
                      • Jan 2007
                      • 718
                      I have no more information other than what is in the bulletin, and have never tried it myself. I assume that the MFP will do a full reboot, not only enter sleep mode.
                      • B0265
                        • Jan 2007
                        • 718
                        Done.
                        • tsbservice
                          Field tech
                          • 8005
                          Done.
                          The following errors occurred with your submission
                          • B0265 has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
                          • B0265
                            • Jan 2007
                            • 718
                            There something strange here, I get this information even after trying to empty the inbox:
                            "Inbox contains 0 messages. You have 65,535 messages stored, of a total 100 allowed."
                            • tsbservice
                              Field tech
                              • 8005
                              This is so-called automatic-spam-prevention function... no just kidding
                              This is known issue, here:
                              https://www.copytechnet.com/forums/s...85=#post716821
                              And here:
                              https://www.copytechnet.com/forums/s...67=#post576194
                              Site admin Aneurysm may have to take a look, you can post new thread in Site Feedback & Questions
                              Let us know.
