Special Firmware for C500 PRO
  • seniortech
    • Dec 2007
    • 180
    I am trying to get special Firmware C12-CMVO for a C500 PRO, for a problem that was mentioned in solution ID YAUS064921EN but am not having any luck.
    'Toner is backing up or solidifying in the cleaning unit box for the transfer belt causing the transfer belt drive motor M18 to bind F23-09 may also be indicated'
    'The special Firmware will keep the transfer belt cooling fan on for a period after the copy process has completed'.
    I have aquired Firmware V 14-00000 but am unsure if this patch is included in this release. Can anyone confirm if this patch is included in this release or point me in the right direction to aquire this patch.
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    I can send that firmware to you if you like. But that firmware is old, what level are you at?
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • random
      remove the filter in the back and never put one back.
      • buster68
        • Nov 2008
        • 181
        I agree with Random.
        C500!!!!
