Outlook requires the use of the second tray
    replied
    Re: Outlook requires the use of the second tray
    Either the driver or outlook is causing the problem. If MS picks the tray it does not matter what the driver is set for MS data will over ride the print driver.
  • Bix
    started a topic Outlook requires the use of the second tray
    Hello,
    All PCs print correctly from Outlook but there is one with problems. He has Windows 7 and when he prints from Outlook, the printer wants to print A4 on the second tray (there's actually A3, then returns the error "Select paper size" on the display).
    When I go to Outlook, even if I set Tray 1 or automatic, Outlook sets Tray 2 again. The setting is as if it were locked. I have also restarted the PC several times, without success
    Some idea?
