Konica c6500
  • Rohullah
    • Sep 2019
    • 37
    Konica c6500
    Hi everyone, i have a problem with c6500, after print 2000 cyan color file, cyan toner is charging too much, Dv unit cover, transfer belt are full of cyan. Cyan is coming out from backside fan. One new toner just printed 500 A5.
    If you have faced this problem or know about this, please advise me.
    Re: Konica c6500
    [ATTACH=CONFIG]43883[/ATTACH][ATTACH=CONFIG]43884[/ATTACH]
    how many pages on the drums/devs/belt?
    Genuine OEM or compatible toner?
    service Pms up to date?
    • Rohullah
      • Sep 2019
      • 37
      Re: Konica c6500
      Hi phil
      Drum and Dv are new. Not worked more than 3000 pages, belt is 30%
      • Rohullah
        • Sep 2019
        • 37
        Re: Konica c6500
        Toner is also genuine. I faced this after i printed a file that is 90% light cyan.
        • tulintron
          • Jul 2014
          • 668
          Re: Konica c6500
          You can check the toner filter on the right side of the printer.
          You can also check the time and amount of toner you are filling.
          • mircea
            • Feb 2014
            • 70
            Re: Konica c6500
            Did you do all adjustments after you replaced dv/drums?
            also try to clean your color reg sensors and do all adjustments again , including color registration and gamma adjustments
            best of luck
            • Rohullah
              • Sep 2019
              • 37
              Re: Konica c6500
              best of luck
              This problem solved, It was DV problem
              Thank you All
              • tsbservice
                Field tech
                • 8010
                Re: Konica c6500
                Thank you All
                Glad you sorted out this but, what exactly was wrong with DV? Old/wrong developer, bad TCR sensor?
                • Rohullah
                  • Sep 2019
                  • 37
                  Re: Konica c6500
                  It was from magnet roller inside dv unit, the roller was charging more and spreading out. So when i changed the DV unit, problem gone.
