AirPrint missing on C360i G00-73 Function 2
  • rrrohan
    • Sep 2011
    • 1977
    Cant find AirPrint on function version 2
    If i set it back to function version 1 the option re appears.
    Mopria still available
  • Bix
    • Apr 2018
    • 1421
    Re: AirPrint missing on C360i G00-73 Function 2
    Hi, if you enable Bonjour for some reason AirPrint will work.
    I send you the function code in private
    • rrrohan
      • Sep 2011
      • 1977
      thank you, will try when i return to work in about 12 hours. is this private? if it works cant i post it to help others?
      • emujo2
        • Mar 2017
        • 1579
        From past experiance on the 8 series, once you drop the version down, enable Air Print, it stays enabled even if you move back up to the current version and is no longer an option in admin. E
        • rrrohan
          • Sep 2011
          • 1977
          Bonjour was already enabled
          • rrrohan
            • Sep 2011
            • 1977
            winner winner chicken dinner
            Must just be a firmware bug but least you got it working for me. thanks.
