i need help!!
  • darry1322
    • Oct 2010
    • 817
    #46
    Re: i need help!!
    Originally posted by BaconSteve
    Am I missing something?
    I don’t work on this brand ....
    He has posted the faulty images a couple of times in the thread.
    On some KonicaMinolta color machines, if you do not follow the setup instructions you will get horizontal colored lines (alternate pages of cyan and magenta) on all color copied pages. Any KM tech has probably had this happen a couple of times just skipping a setup step.
    Since this model is older and his machine probably isn't new, I suspect someone did a clear on the machine and now the setup steps will have to be done to clear the "lines of shame". So called because it means the tech got sloppy during setup.
    • mhmds102466
      • Jul 2019
      • 74
      #47
      Re: i need help!!
      only when copying
        Re: i need help!!
        Originally posted by mhmds102466
        only when copying
        [ATTACH=CONFIG]43931[/ATTACH]
        you have not done the setup procedure correctly ...redo it.
        • BaconSteve
          • Apr 2019
          • 140
          #49
          • BaconSteve
            • Apr 2019
            • 140
            #50
            Re: i need help!!
            Lol, NOW I GET IT. Ok, thanks for the clarification. I scrolled through the thread, I guess I missed the examples. Sorry, not trying to muddy the waters, just trying to help. Thanks again darry.
            • mhmds102466
              • Jul 2019
              • 74
              #51
              Re: i need help!!
              Yes I have lines
              Of nutritious
              And on the glass
              And with photography and put a white paper
              • mhmds102466
                • Jul 2019
                • 74
                #52
                Re: i need help!!
                I did not find the serial number of the scanner behind the machine Is it possible to be the problem of entering the serial number on the scanner from above under Glass
                WhatsApp Image 2019-11-02 at 9.43.23 AM.jpg WhatsApp Image 2019-11-02 at 9.45.48 AM.jpg
                • darry1322
                  • Oct 2010
                  • 817
                  #53
                  Re: i need help!!
                  [ATTACH=CONFIG]43932[/ATTACH] [ATTACH=CONFIG]43933[/ATTACH]
                  No. You have to visit the serial number page but entering values is not needed.
                  • mhmds102466
                    • Jul 2019
                    • 74
                    #54
                    Re: i need help!!
                    Is there another way to return the machine to the factory setting?
                    Or use my c284e-firmware
                    Because I do not know use the machine in copying
                    Because the problem of the emergence of lines problem is damn I do not know where it came from
                    Or do I do a formatting of the hardisk or memory stick, it is possible to solve the problem
                    I am facing the problem more than 3 months I am ready to donate again but I want a quick solution
                    • BaconSteve
                      • Apr 2019
                      • 140
                      #55
                        Re: i need help!!
                        Brother.. I don't know HOW we can stress to this fucker...
                        DO THE DAMN INSTALLATION -= AS WRITTEN.. SKIP NO STEPS .. DO THEM IN ORDER =-
                        You are correct, we have given him the fix FOR MONTHS...
                        he has been provided with the actual guide that comes WITH the machine...
                        As Bill Engvall says " You Just Can't Fix STUPID" here's your sign!
                        • mhmds102466
                          • Jul 2019
                          • 74
                          #57
                          Re: i need help!!
                          I did the steps in the booklet
                          I entered the date and then I entered the serial number
                          The problem still exists
                          • zenonjr
                            #58
                            Re: i need help!!
                            Hi guys someone know the trick how to used the black drum on color on Ricoh MPC5000 ?
                            I just remembered on Ricoh MPC4500 but not on 5000
                            • Toxic
                              • 697
                              #59
                              Re: i need help!!
                              Do you have some P codes showing on display because i think you have damaged drum k watching your photos (top side)?
                              What is machine meter count and parts counter?
                              • BaconSteve
                                • Apr 2019
                                • 140
                                #60
                                Re: i need help!!
                                0
                                Page 2 of 2FirstFirstPrevious12Results 11 to 15 of 15
                                Thread: Bizhub C652 horizontal lines
                                Thread Tools
                                Display
                                02-20-2014 #11
                                Okeer
                                Guest
                                Re: Bizhub C652 horizontal lines
                                I had the same trouble with a C452 and it was a memory error on the MFP board. After replacing the MFP board, everything was fine
                                Reply With Quote Reply With Quote
                                02-20-2014 #12
                                oommiiddaann oommiiddaann is offline
                                Join Date
                                Feb 2012
                                Posts
                                27
                                Rep Power
                                0
                                i think swap CCD because this lines is from bad image creation from scanner ccd not a physical problems in scanner like scan motor mirrors and other scan parts.
                                02-21-2014 #13
                                methogod methogod is offline
                                Join Date
                                Dec 2008
                                Location
                                Baltimore, Maryland
                                Posts
                                727
                                Rep Power
                                30
                                if it prints ok, its a memory issue - usually fail memory stick has gone bad.. replace, then if still there go to the mpf board...
                                but check all connectors first, and does the same lines happen when scanning?
                                02-21-2014 #14
                                Synaux Synaux is offline
                                Join Date
                                Mar 2012
                                Posts
                                923
                                Rep Power
                                30
                                Quote Originally Posted by methogod View Post
                                Agreed, if the issue shows on internal prints its most likely the memory. TAUS1001639EN
                                tnrtt has a lot of things to check, but probably the quickest and easiest thing to do is a memory check in Service Mode.
                                If NG try memory modules.
                                Then unfortunately the replacement of the MFP board.
                                However, do not depend on those memory checks as being unequivocal I have had memory checks pass even with a bad DIMM.
                                03-01-2014 #15
                                tnrtt tnrtt is offline
                                Join Date
                                May 2013
                                Location
                                phoenix, AZ
                                Posts
                                84
                                Rep Power
                                14
                                Quote Originally Posted by Okeer View Post
                                Thanks a lot, Okeer. Replacing the memory did the trick. This forum is great. No matter how weird the problem, somebody here has encountered it.
