Konica C250i / Develop + 250i Firmware Update
  • flippinsweet
    • Oct 2013
    • 34
    Hi just a quick question about firmware update procedure on the C250i range. I have access to the Develop website and can download the firmware but can't find the service manual anywhere to view the procedure. The firmware doesn't mention anything about changing the software switch or hex assignment like other models, just to refer to service manual for installation.
    We only have 1 of the +250i Develop machines out at the minute and the customer is complaining about the touch screen being slow and sometimes unresponsive. Any help appreciated
  • arahael
    • Mar 2013
    • 97
    Re: Konica C250i / Develop + 250i Firmware Update
    You can find service manual at SMART link at main page dbox Screenshot_2019-11-07 Knova Knowledge Central.png then you can find service manual.
    I think you should more practice with new KNOVA/ dbox. To find what you need. There is also service manual how navigate through new layout
    Best regards
    • Bix
      • Apr 2018
      • 1421
      Hello,
      The update fw procedure is the same as the 8 series. The stop and reset buttons can be found behind the display by removing the cover.
      Regarding the dipswitch, it depends on the firmware you are installing. On the firmware document you will find all the information.
      At the moment up to G00-45 it is always version 1.0, no dipswitch necessary.
      The G00-73 firmware is version 2.0. You need to change the dipswitch 25 from 00 to 01
      Remember to restart the MFP after this change
