BizHub Simulator Problem
  • caltuntas
    • Nov 2019
    • 5
    Hello,
    I followed instructions on simulator manual pdf and installed all the tools needed, but I couldn't successfully start simulator on my laptop(Windows 10). I attached all the screenshots that I took which show the configuration I made.
    As far as I can see after I start simulator, it tries to boot up fedora virtual OS but it waits at user login prompt,and after a while it says "unexpected error occured, Restart the system". Is it normal or can it be root of the problem, can you please help me? Thank you.
    VirtualBoxVM_2019-11-11_22-31-45.jpgVirtualBox_2019-11-11_22-23-26.jpgVirtualBox_2019-11-11_22-23-21.jpgVirtualBox_2019-11-11_22-23-01.jpgVirtualBox_2019-11-11_22-22-56.jpgVirtualBox_2019-11-11_22-22-43.jpgRemoteSimLinClient_2019-11-11_22-32-36.pngexplorer_2019-11-11_23-00-49.jpgexplorer_2019-11-11_22-58-29.jpgexplorer_2019-11-11_22-22-04.jpg
  • Bix
    • Apr 2018
    • 1421
    Re: BizHub Simulator Problem
    I have not understood what simulator you are trying to start but in infohub there should be one already configured of konica minolta, available online (if you mean the screen).
    Which model is it?
    • caltuntas
      • Nov 2019
      • 5
      Which model is it?
      I am new to konika minolta development and trying to write a "hello world" application on konika minolta MFP. After that I want to write an application on MFP that will show some kind of custom user login dialog and intercept user login from the app. For that purpose I downloaded following tools from DSP Portal
      BEU bEST OpenAPI Starter Kit 5.2.0a (contains list below)
      • MFP firmware
      • OpenAPI Sample applications
      • OpenAPI Tools
      • SDK
      • SimWin ----> bizhubC558Simulator.exe
      • WSDL
      And after that I installed bizhubC558Simulator by following instuctions from BIZHUB_C558_SIMULATOR_V2.10_MANUAL.PDF. But I coudn't start simulator. That was the problem I was trying to solve.
      • Bix
        • Apr 2018
        • 1421
        Really interesting, I'd like to try!
        Where is it? I know that applications should be developed in Python
        • BHM
          • Feb 2011
          • 126
          Does not sound fishy at all.
          • caltuntas
            • Nov 2019
            • 5
            • caltuntas
              • Nov 2019
              • 5
              If you have a developer account, you can find it from resources section. Not sure about Phyton examples are mostly in .NET and XML web services in SDK
              • BHM
                • Feb 2011
                • 126
                Perhaps I am misunderstanding what you are trying to accomplish. The machines have a built in Account Track and User Authentication feature. Logins can either be created on the device or it can use Windows authentication as well.
                There are also software programs such as PaperCut that can track, limit and report usage.
                Your "intercept user login" comment was a little concerning. Again, perhaps I am not understanding what you are trying to do.
                • caltuntas
                  • Nov 2019
                  • 5
                  You got my point actually, I'm trying to do exactly similar to what PaperCut software does. Built-in features you mentioned does not meet my customer requirement such as "Sales department users should swipe identity card but only some users of it is allowed to print" so I will check by custom login prompt if a user from sales department is one of allowed users to print etc..I hope, I could explain what I'm trying to solve.
                  • BHM
                    • Feb 2011
                    • 126
                    Ahhhhhh, that makes sense.
                    Fyi, account track can set who can print and how many pages.
