BIZHUB C6500 loading paper askew
  • arturceglowski
    • Mar 2019
    • 5
    Hallo,
    I have two problems. I cannot set the skew and the paper is loading askew.
    Attach image print patern no 16. Please help.
    Re: BIZHUB C6500 loading paper askew
    Originally posted by arturceglowski
    Hallo,
    [ATTACH=CONFIG]44054[/ATTACH]
    well ok....
    what tray is it feed from?
    what type/size paper?
    do size/type match on copier?
    are the guides tight on paper?
    how many pages on machine?
    what have you done to correct issue?
    personal or customer machine?
    are you a tech or end user?
    PhilB. "The Dentist"
    • arturceglowski
      • Mar 2019
      • 5
      well ok....
      bypass
      offset 90g 320x450mm
      testy
      yes
      bw 678467
      color1246895
      service print adjustment
      fd+cd mag. cs skew test print add as image attachnent
      check adu rollers an cleaning
      customer bizhub c6500 pro
      low tech
      • Toxic
        • 697
        Is it happens on all paper sizes and all trays or just that combination you already quote?
        Did you try to clean registration roller?
        • arturceglowski
          • Mar 2019
          • 5
          Yes it happens on all paper sizes and all trays.
          If you mean A03UR7C100, yes i clean this roller. I removed the whole section and checked it manually, the paper moves straight.
          • methogod
            • Dec 2008
            • 917
            loop adjust?
            • arturceglowski
              • Mar 2019
              • 5
              Originally posted by methogod
              loop adjust?
              I did the test again. Paper rotation unchanged by 2 mm
              • methogod
                • Dec 2008
                • 917
                what size is the paper you are testing?
                i would check this...
                Dropbox - REGISTRATION_UNIT_ADJUSTMENT.pdf - Simplify your life
                easy to mis-align.
                • arturceglowski
                  • Mar 2019
                  • 5
                  easy to mis-align.
                  difficult to .....
                  Any other idea?
                  • methogod
                    • Dec 2008
                    • 917
                    difficult to .....
                    [ATTACH=CONFIG]44079[/ATTACH]
                    Any other idea?
                    what did you replace on the reg unit?
                    i would take it back part and reinstall, something must be off...
                    there are springs that have to be clocked correctly.
                    run the test print on differnt stock? maybe bad paper?
                    run the test on 8.5x11 or A4 short edge first..
                    run the test on card stock (A4 AND A3)
                    looking to isolate the issue...
                    SEE WHAT GIVES...
                    I HAVE A USED GOOD REG UNIT IF YOU WANT TO BUY IT.
