Konica Minolta C6500 Yellow image problems
  • matsan_offset@yahoo.com
    • Sep 2016
    • 41
    [Misc] Konica Minolta C6500 Yellow image problems
    Hi
    My machine problems
    yellow darkening at certain intervals.
    15% yellow printed on the photo.
    what could be the problem?
    thank you for your help
  • Bix
    • Apr 2018
    • 1421
    Re: Konica Minolta C6500 Yellow image problems
    Please provide more details.
    Counter? Any OEM? Have you already replaced something? Periodic maintenance?
      • Sep 2016
      • 41
      I removed the yellow developer unit because the yellow rectangular line appeared. It was like this when I put it back on. if the drum sees light? did not see direct sunlight
      • Rohullah
        • Sep 2019
        • 37
        Originally posted by matsan_offset@yahoo.com
        Hi
        My machine problems
        It seems like OPC drum problem. Change drum or interchange with another color to check.
          • Sep 2016
          • 41
          I will test it as you say tomorrow.
          • Rohullah
            • Sep 2019
            • 37
            Based on manual, direct sunlight will effect on drum
            • methogod
              • Dec 2008
              • 914
              That's not DV unit. That's drum or Corona.
              Swap yellow drum with Black drum, test - see if line moves with drum (mark them accordingly when swapping for your records).
              If lines stays in yellow, would then swap back, and swap corona's. Test again...
              should give us more info at that time... Not belt IMO, could be yellow transfer roller, but doubt it, most DV issues repeat more often.
