C8000 gray bakcground
  • jiceys
    • Dec 2017
    • 9
    Edit Report
    hi, I have a problem on a C8000 I have a gray background on everything I print. I changed the black corona, swap the drum, the head of the writings. but the problem is still present.I have even changed the black development unit, but I still have the gray background in everything I print. Have you some solution for me please? when I'm doing a patterne test 49, I have a band at the level of black only.
  • dagoof
    Still learning...
    • 220
    Re: C8000 gray bakcground
    Ensure your SCSI cable between the machine and Fiery are correctly seated.
    Could be worth changing your black Dev - I've often seen it expire before life and it'll leave a background toning.
      Originally posted by jiceys
      Edit Report
      'shot gunning' a problem is VERY costly ...
      you mention NOTHING about the page counts on machine/supplies.
      did you make all proper adjustments after replacing parts
      Genuine Toners/Drum?
      "head of writings?" you mean Laser Asmy?
      Are you a trained tech or end user
      do you have a service manual?
      • jiceys
        • Dec 2017
        • 9
        Thank you for answering me.
        I changed the black developer, I also checked the cable. but I still have the same problem. there is the same black background when I print the test pattern 43 in the technical mode, i have the same black back in all the sheets.
        I am a user and i have experience in konica printers. I have the technical manual. of C8000.
        the total counter is 2,517,080.
        • jiceys
          • Dec 2017
          • 9
          I made all the adjustments in the technical mode after replacing parts .Yes it is genuine toners/drum. there is the same black background when I print the test pattern 43 in the technical mode, i have the same black back in all the sheets.
          I am a trained tech in konica printers. I have the technical manual. of C8000.
          • tsbservice
            Field tech
            • 8009
            Sooo, user or trained tech
            Also posting a sample would be nice.
            • jiceys
              • Dec 2017
              • 9
              I send an attached picture
