bizhub 4020 where is autoswitch tray?
  • Bix
    • Apr 2018
    • 1421
    Hi, does anyone remember where I can find the setting to disable the tray autoswitch setting when the paper ends on bizhub 4020?
    thank you
  • tsbservice
    Field tech
    • 8010
    Re: bizhub 4020 where is autoswitch tray?
    Try this:
    Configure MP menu - set to Manual instead of default Cassette. That shouldl set MP feeder only for manual print jobs.
    • Bix
      • Apr 2018
      • 1421
      Try this:
      Hi, thanks for the suggestion but in the normal settings I could not find this setting.
      Not even by pressing 2, 6. The only setting I could find is the feed source. I can set manual but if they make a copy, it requires printing from the bypass.
      Let me know if you have any other advice.
      Bix
      • Bix
        • Apr 2018
        • 1421
        Perhaps I have identified. It's called MU configuration
        • tsbservice
          Field tech
          • 8010
          Tray Linking
          This feature links all trays with the same paper size and type. When a tray becomes empty, the printer
          will feed paper from the linked tray.
          Available options:
           On
           Off
          • Bix
            • Apr 2018
            • 1421
            Thanks a lot tsbservice, it's the exact option!
            Unfortunately, the German translation of the manual is not very intuitive. I was convinced that that option would disable the visibility of those trayers.
            Thanks again!
