konica 2223
  • issahodeh
    • Jun 2007
    • 22
    konica 2223
    Please advice with : what the service adjustment codes that has to be done after replacing the ( Drum , Developer) for Konica 2223 . please in steps
  • Luther
    • May 2006
    • 682
    Check your private messages and good luck
    • kiwitechnician
      • Dec 2008
      • 54
      Be sure you replaced the drum and developer then go
      1.47 mode,code 91 start (clear the drum)
      2.47 mode,code 90 start (clear the PM)
      3. 47 mode,code 51 start( L-detection)
      keep the order I have written otherwise you get F26 message.
      • Zoren
        Technicien de copieur
        • 99
        i bet he can still reset that F26 in another developer setting... otherwise, it can be done in another sp mode....
        Just came out from hybernation.....
        • kiwitechnician
          • Dec 2008
          • 54
          I meant If you reset PM counter and then don't do L-detection I am sure you get F26 message.
          • Zoren
            • 99
            i know what u meant...
            sometimes doing L-det. even with a new developer can get u an F26 code. experienced this in a dry and humid country...
            • issahodeh
              • Jun 2007
              • 22
              thanks
              many thanks for all of you
