Copy Ratio stated wrong type
  • Ong CZ
    • Jan 2020
    • 6
    [Misc] Copy Ratio stated wrong type
    Hi Guys,
    I have some issue when going to enlarge the image for copy. It shows the ratio like in the attachment.
    Instead of shows A4,A3 or B5...
    Any idea,guys?
    Thanks.
    Re: Copy Ratio stated wrong type
    Originally posted by Ong CZ
    Hi Guys, I have some issue when going to enlarge the image for copy. It shows the ratio like in the attachment. Instead of shows A4,A3 or B5... Any idea,guys? Thanks.
    cannot open it
    shows Ax Bx do you want inch format?
    are you a tech with service manual?
    • Ong CZ
      • Jan 2020
      • 6
      Hi Phil,
      Normal when inside copy mode..press on zoom/ratio to enlarge the image..normally will shows in A4-.A3 or B5-A4 for example..but mine here show different size,such as 11x17->8 1/2x11 ...
      Yes, im a tech but dont have service manual.
      Thanks.
        Hi Phil,
        Thanks.
        change unit of measure
        is this 2nd hand unit?
        • Ong CZ
          • Jan 2020
          • 6
          Hi Phil,
          Nope. Its new machine and already used since 2016.
          May i know how to change it..i did change the measure from inch(Fraction) to mm(Numeric Value) in utility/system settings/measurement unit settings
          But nothing change.
          Thanks.
          • tsbservice
            Field tech
            • 7998
            Did you do some sort of initialization or clear all data? Looks like wrong region settings.
            • Ong CZ
              • Jan 2020
              • 6
              Hi tsbservice,
              I just replaced new mfp board due to the machine prompt key in serial number and tpm chip error.
              Thanks.
              • tsbservice
                Field tech
                • 7998
                What machine model? Did you follow the book for MFPB replacement?
                DO WE NEED TO PULL ANSWERS FROM YOUR MOUTH ?!?
                I feel now more like Phil B aka The Dentist
                • Ong CZ
                  • Jan 2020
                  • 6
                  Hi tsbservice,
                  KM-C554e..yes i did follow all the steps from the replacement manual.
                  • Ong CZ
                    • Jan 2020
                    • 6
                    Hi Guys,
                    Its fixed.Just change the setting in(svc mode->System 1 -> Marketing Area -> US change to others2).
                        Hi Guys,
                        FYI mm vs inch is most times Regional/Market/Timezone across ALL brands
                        glad you got it fixed.
