C364 with Lines of Shame
  • tulintron
    • Jul 2014
    • 651
    Good morning guys.
    I have 04 C364 in the field, with an average of 200k counter, which are making my hair fall.
    They present the lines, so I perform the procedure and they disappear.
    After a few days, they come back with the lines.
    Have any of you been through this?
    Any firmware that solves the case?
    Thank you all.
  • Bix
    • Apr 2018
    • 1421
    Re: C364 with Lines of Shame
    Hello by chance also lose date/time?
    Are you proceeding correctly with the installation process? The phenomenon should happen when you make a color copy but not when you send a scanner.
    What firmware do you currently have installed?
    • tulintron
      • Jul 2014
      • 651
      The same procedure was done on 20 printers. Only 04 show this line error after a few days.
      The firmware installed on all printers is the G20-72.
      They have not lost their date and time settings.
      Of these 04 printers, only one lost the meter. After the installation procedure, she fixed the new meter, only 72 pages.
      • tsbservice
        Field tech
        • 7635
        Any old battery backup on MFPB loosing settings?
        Copied this from other thread.
        IMG20190211230545 — imgbb.com
        • tulintron
          • Jul 2014
          • 651
          I thought about that hypothesis too. But the useful life of these batteries are very long. So I was in doubt.
          These batteries make up the body of the NVRAM.
          If they don't lose counter, I don't believe the battery would be the cause.
          But I'll find out.
          • tsbservice
            Field tech
            • 7635
            But I'll find out.
            Yeah, it's just speculation although we think down the same line. Did you tried Clear All Data?
            • tulintron
              • Jul 2014
              • 651
              Yes.
              I clean all data, update and perform installation procedure
              • tsbservice
                Field tech
                • 7635
                @tulintron read this post from Gergő:
                C454e "TPM chip has been changed"
                • tulintron
                  • Jul 2014
                  • 651
                  thanks, but this is not my case
