Konica Minolta bizhub 754e C3101 !
  • rvptor
    • Aug 2018
    • 19
    This is the machine above. I changed the main board, fuser, rear arm, transfer belt, it still throws out the same code. A colleague tried to reset the machine to the factory ones but that didn't solve the problem either ..... If anyone has met before, thanks in advance: D
  • jwai
    • May 2018
    • 513
    Re: Konica Minolta bizhub 754e C3101 !
    Try the fusing roller separation motor and/or relative parts?
    • CompyTech
      Super Tech
      • Feb 2011
      • 706
      There's a plastic bushing that sits on the drive shaft of the M29 that cracks. Design was changed to a brass bushing. Might be better off replacing the fuser drive assy.
      • rvptor
        • Aug 2018
        • 19
        Thanks for your response...I forgot to mention that i already implement fuser drive assembly as well...
        • Bix
          • Apr 2018
          • 1421
          Hello, the manual also indicates the replacement of the PRCB
