Scanning of 130F
  • kiwitechnician
    • Dec 2008
    • 54
    Scanning of 130F
    Hi guys, can anybody help with scanning on this machine. I am not sure about that how to do.
    I instalated the GDI driver which should be together with scanner driver but I still get the message: Can't connect to 130F scanner
    If I want to install the scanner the Xp can't see him but I am sure it is there.
  • ni311
    • May 2008
    • 658
    Is the driver listed in Device Manager / Imaging devices?
    From my knowledge, once you installed the printer driver, the scanner came with it automatically.
    Konica Minolta Error Codes - Explanations and Solutions
    • kiwitechnician
      • Dec 2008
      • 54
      I thought the same but I couldnt see it in device manager. When I tried to connect the scanner I got the message ,,failed to connect the scanner,,
      The local connection was fine I could print the test page.
      • harry2007
        • 52
        130f
        -uninstall previous driver (130f)
        -delete konicaminolta 130f folder on C.
        -restart pc
        -do not connect copier to pc at this time
        -insert original CD an follow the wizard to the end
        -insert USB cable
        -when ask about path -browse to konicaminolta 130 f folder on C.
        -for scanning use a spec program (adobe, corel, irfanview, acdsee,..)
        enjoy !
        http://copierservicereset.com
        • kiwitechnician
          • Dec 2008
          • 54
          I thoght the same but I was wondering your opinions and experiences with this machine. The less machine the bigger issues,bloody machine.
          I will try it on Monday, let you know what happens.
