MACHINE ERROR BIZHUB C284e (C-FA14) WITHOUT SOLUTION, ANY ADVICE?
  • eduards06
    • Aug 2025
    [Error Code] MACHINE ERROR BIZHUB C284e (C-FA14) WITHOUT SOLUTION, ANY ADVICE?
    The error exits when i turn on the machine with the hdd (hard disk) enabled, and when the hdd is disabled the error disappears, but the machine becomes slow and does not scan, how do i solve this error?
  • copyrooks
    • Oct 2013
    • 210
    Re: MACHINE ERROR BIZHUB C284e (C-FA14) WITHOUT SOLUTION, ANY ADVICE?
    Sounds like the your HDD is a goner. Replace it, re enable it in service mode. Perform a logical format and get your movie data ready.
    • tulintron
      • Jul 2014
      • 668
      Try the physical and logical format on this same HDD. If you are successful in the process, get a firmware error C-FA14. In some cases, you don't need to replace the HDD
      16. C-FA14 (0x6088) occurs and MFP may not return from Low Power mode. [ERBJTS1600884480]
      • emujo2
        • Mar 2017
        • 1579
        Youb could try doing a physical format or replace the drive...
        • Bix
          • Apr 2018
          • 1421
          I have a C364e with C-D010. The MFP works only if you disable HDD. Otherwise C-D010 comes out and I have already replaced HDD, formatted and rwritten the firmware.
          This happened after the plug was brutally unplugged without turning off the printer. If it's not an HDD problem, it's an MFPB problem. I hope it is not the same thing because FA14 is very generic.
          even my C364e with HDD disabled no longer goes into standby. So the probability that it is MFPB is higher.
