I'm looking for some advice on this one (to fix the machine - fixing the tech is hopeless
Here's the history: the tech updated firmware to GDL-M1 without consulting the DLBT that states "*This FW reboots automatically 60 seconds after the completion of the FW update.Therefore, please disconnect the USB memory immediately once the FW updating process has been completed." He Left the USB in the machine and shut it off when he heard it rebooting. Once restarting, he found the meters were at zero. Tried to reflash folloowing directions, but no change. Machine seemed to work fine, just meters reset.
Six weeks later, C-D382 pops up, no call from customer, skip a day, code pops up three times and customer calls. (We haven't actually seen the code, as the machine reboots automatically.) Replaced Hard drive, everything seems OK.
Yesterday, code pops two more times.
We figure the counter mismatch and other nonvolatile data from the original screw-up is to blame. Is there another way to get the machine to Recover Data without seeing the code on the screen, or is it too late for that?
Thank you for your advice.
