Bizhub 654e faded low density image/ Image registration error
  • popup2u
    • Jan 2020
    • 21
    I have a 654e that shifts that starts making copies fine and then eventually shifts the image and cuts off the right side of the image; while printing some copies about halfway through images switch from normal density to extremely light, low density images. The drum unit is at 130K, transfer belt is at 115k, developing unit is at less than 5k (just replaced), TCR value is at 6.82%, and the the idc voltage is 4.8%, the gradation dark is at 418 and the hue is at 382; each of those three imaging units(drum, transfer belt, and developing unit) were replaced individually and the errors still occur. I also replaced the HV Board 2 and that didn't get it either. The copier has the G20- M0. ANY ideas?
  • popup2u
    • Jan 2020
    • 21
    Re: Bizhub 654e faded low density image/ Image registration error
    image stabilization, gradation adjustment, transfer belt cleaning and charging CH cleaning, was performed also
    • tech51
      • 846
      • popup2u
        • Jan 2020
        • 21
        I'm assuming that is for the registration error?or would that cause both problems
        • tech51
          • 846
          Seems to cause both faults.
          • allan
            RTFM!!
            • 5445
            Stop the machine mid print and pull the transfer belt to check how much toner is not transfered.
            Also pull the drum and check the image density on there.
            Then you will have a better idea if the problem is with development, primary or secondary transfer.
            Whatever
            • popup2u
              • Jan 2020
              • 21
              Just checked my actuator and it stuck as soon as I pressed it. I'll replace it and let you all know my results
              • popup2u
                • Jan 2020
                • 21
                replacing the spring and actuator fixed my issues. Thank you all for the advice!
