Konica C754e CE Mode Imaging Process Adjustment PRINTER FEET have values
  • denvertan
    • May 2019
    • 86
    These C754e is very different from the normal Konica Machine I see before.
    It have value at PRINTER "FEET" at CE Mode Imaging Processing Adjustment.
    I have try to run Stabilizer + Initialize Data
    Then redo the Imaging Processing Adjustment again.
    But the FEET still have value.
    Up to my knowledge PRINT FEET value should be ZERO only Copy can have values other than zero.
    May I have your guidance to fix this ? I have been going through the service manual but only mentioning is zero, if not zero rerun.
    But I have attempted like 10 reruns.
  • Bix
    • Apr 2018
    • 1421
    Re: Konica C754e CE Mode Imaging Process Adjustment PRINTER FEET have values
    You can't have a value of 0. The value of 0 is perfection and you don't have it with a new MFP either. Temporarily get the value zero when doing the initialization but it is only a fantasy value. The tolerated value is from +/- 100
    • allan
      RTFM!!
      • 5462
      [ATTACH=CONFIG]45015[/ATTACH]
      So what is wrong with the machine?
      If it ain't broken don't fix it...
      Whatever
      • tsbservice
        Field tech
        • 8061
