Disable supplies notification on mac
  • Methmann
    • May 2009
    • 72
    Hello everyone
    We have disabled supplies notification in service mode for drums etc. on the machine.
    But mac users still get notification about expired drums etc. on their mac computers.
    Is there any way to avoid this??
    Thanks in advance :-)
  • mansart
    • 852
    Re: Disable supplies notification on mac
    Disable SNMP on the copier
    • Methmann
      • May 2009
      • 72
      Ahh, i will, thank you :-)
      • occus
        • 337
        That works but you have to know in a mixed system with mac and win then you get trouble with printer is offline on the win computers.
        Maybe the 227 switch (hide unit status) can do the same but until now i have no experience because i haven't been using it for long. For contracts its a good thing.
        • tsbservice
          Field tech
          • 8019
          Use switch 230.
            why not just change the parts out when they have reached PM cycle? no CQ/PQ problem calls, customer doesn't feel you are doing the service correctly... boss won't get calls from irate customers.
            never understood why you would put yourself in that mess.
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              Same here end of life means replace
              Regards Mark
              • Methmann
                • May 2009
                • 72
                Tell that to My boss. It costs money, and its contract customers 😉
                • Methmann
                  • May 2009
                  • 72
                  Should i use switch 227 or 230. And Edit to hex what? 🙂
                  • mattcoop11
                    • Jun 2015
                    • 12
                    Switch 227 hex 80
                    • Methmann
                      • May 2009
                      • 72
                      Originally posted by mattcoop11
                      Switch 227 hex 80
                      Nice, thank you! I will try that ;-)
                      • Methmann
                        • May 2009
                        • 72
                        Switch 227 hex 80
                        Unfortunately, it didnt help. Mac users still get warnings about photoconductors
                        • tsbservice
                          Field tech
                          • 8019
                          Do you have manual? Did you read it? It's clearly stated there what value should have software switch 230 to not sending machine MIB info.
                          • Methmann
                            • May 2009
                            • 72
                            Found it It says, i should set SW230 to 08.
                            But when i set SW227 to 80 or SW230 to 08. And press fix. Goes back, and in again, the switch settings both goes back to 00
                            • allan
                              RTFM!!
                              • 5462
                              Find the option to disable SNMP somewhere under network settings in the admin settings.
                              Whatever
