Konica Bizhub C224e Image Problem, Please Help
  • stryder
    • Apr 2014
    • 33
    Hey Guys,
    I'm having a problem with a BH C224e, attached is a demo page printed from the machine and a copy of that demo page on the glass and on the adf. The magenta is off image, any suggestions? Thanks in advance.
    Image problem.pdf
    Re: Konica Bizhub C224e Image Problem, Please Help
    Originally posted by stryder
    Hey Guys,
    [ATTACH]45085[/ATTACH]
    try scanner calibration
    • stryder
      • Apr 2014
      • 33
      Tried it, but unfortunately it says "Stabilizer NG" so cannot go through with the process
      • jwai
        • May 2018
        • 510
        Try CCD module?
          then start cleaning optics carefully
          if it fails again re init scanner
          • Takhnamishvili
            • Mar 2019
            • 53
            Hey Guys,
            Remove transfer belt unit and clean both IDC sensors, after reassembling, perform image stabilization from service mode.
            • K-3
              service technician
              • Feb 2018
              • 51
              reseat adf connections and all connection to the scanner unit, then run a self diagnostics to see if any show a ng, if not the start with ccd cis dual scan image board, mfp board
