Error Code C-3B02 Bizhub C652
  • Khumz
    • Feb 2020
    • 63
    Which part to look into first?. Definitely cant change all listed parts at once according to error code definitions.
  • tsbservice
    Field tech
    • 8020
    Re: Error Code C-3B02 Bizhub C652
    Did you try using Trouble Reset?
    • Khumz
      • Feb 2020
      • 63
      Trouble reset is not working. Same problem pursists.
      • tsbservice
        Field tech
        • 8020
        Replace the IHPU. Next replace the Coil.
        • Khumz
          • Feb 2020
          • 63
          It sounds so stupid to say i cant access the IHPU. I stripped the machine from the back, removed Main PSU but cant see the IHPU. I guess i was too tied.
          • tsbservice
            Field tech
            • 8020
            Eghhh, you don't have a manual How can you service machines that way, imo it is really stupid and time consuming.
            Last hint before I'm done with this. IHPU is behind covers, front-upper-right side. Remove 3 plastic covers and some metal shieldings to get IHPU.
