Bizhub 250 Twain Scanning
  • DocuSystems
    Service/IT/Integrator
    • Jan 2007
    • 54
    Can't get this to work. Environment is: Bizhub 250 with HDD, Networked with a Fixed IP in a Windows 2003 Domain. The workstation has XP Pro. I've updated the firmware on the Bizhub, and installed the HDD Twain driver, but when I try to acquire a scan, the driver asks for an IP and then tells me that the device is not supported. Anyone out there had any luck with this?
  • fixerboy
    • Nov 2006
    • 17
    biz 250
    are you trying twain or scan to harddrive if your trying with the pagescope software use the lastest ver.2.0
    • DocuSystems
      • Jan 2007
      • 54
      Twain
      Trying to scan using the Twain Driver. It's for a Medical Database/Patient package called AR. This software uses twain to import documents into the patient file.
      • DocuSystems
        • Jan 2007
        • 54
        Resolved
        The problem was the firmware. Upgraded to the lates (49) and everything started working. Thanks for any posts to this thread!!
        • gateway.vly@gmail.com
          • Dec 2007
          • 52
          HOW TO UPDATE firmware ON BIZHUB C250
          Tell Me How To Update Firmware On Bizhub C250
          • fixerboy
            • Nov 2006
            • 17
            c250 firmware update
            There is a firmware updater that konica minolta uses to write to the card. A compact flash card 129mb is needed
              • Dec 2007
              • 52
              where i can find the fireware
