4402P imaging unit not detected
  • Bix
    • Apr 2018
    • 1421
    hi, I have a bizhub 4402P which indicates "image unit not inserted or not detected". The customer has already tried changing the imaging unit with a nearby bizhub 4402P but the error continues. In addition, the imaging unit works on other models.
    Being this client far away, what could have happened?
    thank you in advice
  • tsbservice
    Field tech
    • 8053
    Re: 4402P imaging unit not detected
    From what I'm reading from manual you can have bended(or contaminated) contacts for IU. Last step is to reseat the smart chip contact cable on the controller board.
    • Bix
      • Apr 2018
      • 1421
      I found the cable for the soft imaging unit. Once I hung up well, the printer gave me toner cartridge error. I removed and reinserted the image/toner unit, the printer started working again
      Strange that the problem only appeared now. has been installed for several months.
      However, for now, problem solved.
      Thank you!
      • WLIT
        • Jan 2020
        • 40
        I have had good luck with slightly bending the contacts in the mfp that mate up with the imaging unit contacts. If you examine the ones in the mfp with a flashlight you may see one or more of the 4 contacts are not aligned with the rest. You can use a small flat blade screwdriver and slightly pry each contact to the right so that they form a straight line top to bottom. This will usually give a better connection to the IU and allow it to keep going until a print quality issue would warrant replacement.
