Help. Konica Minolta Bizhub C759 double/ghost prints on 11x17 only.
  • copiers01
    • Mar 2018
    • 23
    #16
    Re: Help. Konica Minolta Bizhub C759 double/ghost prints on 11x17 only.
    Originally posted by RUSORIZO
    Hello Everyone,
    We have a Konica Minolta Bizhub C759 and having a problems with the print outs, with red/magenta shadows double/ghost prints. The problems only appears when we print on a 11x17" size paper but for a 8x11" the prints are good. You can print one at a time and they will all look good. But print like 10 or more and the first few will look good and then the rest will start to double/ghost. Please see below for sample prints:
    [ATTACH]45343[/ATTACH] [ATTACH]45342[/ATTACH]
    The KM Bizhub C759: 2 years old
    Total Counter: 86,730
    The fusing unit is new
    the 3 imaging units and drum are new CMYK
    Did perform the Image Stabilization Only, Image + Stabilization, Print Skew Reset, and Color Registration Adjust but to no avail.
    I appreciate the help.
    Hi,
    I had a similar problem with the C458 e, I replaced the print head and the problem was solved.
    • Seijinie
      #17
      Does anyone have any solution for this?
      I replace almost all part of C759 machine but still confuse what is the reason for this.
      MFP board, Transfer belt, idc, supply board...
      • t85ster
        • Mar 2015
        • 39
        #18
        Are your guys trained/experienced on the Bizhubs?
        1. Remove the Transfer Belt Unit and clean the two color registration sensors properly.
        2. Make sure to use only OEM Toner!
          Does someone have a Konica Minolta Bizhub C759 Service Manual? Thank you.
          https://www.copytechnet.com/forums/s...nual-requests/ ALL manual requests are to be placed in that forum per forum rules.
          • amirmajnooni13
            • Oct 2024
            • 1
            #20
            hello
            I also have this problem, everything is fine at 600 dpi But it casts a shadow at 1200 dpi I changed many parts, but the problem was not fixed (transfer unit.Laser unit.IDC sensor.image unit black.register unit)
