di 470 print controller question
  • brent
    • Nov 2008
    • 1213
    I have a minolta di 470 and I was told that a pi 5501 would work in it. I know it is supposed to be used with a pr4700e. but I thought I would ask the forum here first before I tried such a thing. and if this will work what drivers would I use. thanks guy's
    brent
  • masterteknicion
    • 48
    Yes it will work. See attachment.
    • brent
      • Nov 2008
      • 1213
      controller
      ok thanks for the information. so it was kind of confusing. do I need to do anything different for the controller type or peripheral mode if I am just trying to get the machine to print? again I am installing a pi 5501 onto a minolta di 470. thanks for your time.
      brent
      • buster68
        • Nov 2008
        • 181
        The Pi5501 is not supported on the Di470; the Di470 supports the Pi5500 and the Pi4700e. The Pi5501 is compatible only with the Di450 and Di550.
        • brent
          • Nov 2008
          • 1213
          this is why I asked this question. some of you say it will work. and some say it will not work. my supplier did tell me that it would work... I just would hate to have to purchase a 4700e when this 5501 I have would work
          thanks for all your imput
          brent
          • brent
            • Nov 2008
            • 1213
            controller
            I found a technical advice document from minolta number
            TAUS0643066EN00 and it did state that the pi 5501 has not been tested and approved for use with the di 470. I am going to find a pi 4700e and do it the right way.
            thanks again guy's
            brent
            • pepper38_cnd
              Field Service Manager
              • Aug 2005
              • 1075
              This may prevent a little confusion in the future
              Now into Ip TV KODI Boxes
              • masterteknicion
                • 48
                The attachment I provided to you a couple of days ago has PI5501 all over it about how to set the machine up, using the pi5501. It will work, I have been doing this for over 20 years and I am an ex M tech. that can tell you this will work. I have done it many many times.
