9401 bizhub 4052
  • Genotrom
    • Feb 2020
    • 77
    9401 bizhub 4052
    Hi, I have a bizhub 4050 with a 9401. It is a quarantine, I have only a few attempts.
    It concerns the lamp scanner. Some advice?
  • copyrooks
    • Oct 2013
    • 205
    Re: 9401 bizhub 4052
    If you can't order parts you can try reseating connectors and trouble resetting. I have a copier in our area with the same code popping up intermittently, we have tried reseating connectors and updated firmware and trouble reset works for a bit. We are hesitant to order a replacement scanner since its NOT covered under warranty through Konica.
    • tsbservice
      Field tech
      • 7635
      1. Easy things - Did you try trouble reset?
      • ivovb
        • 695
        I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
        • Genotrom
          • Feb 2020
          • 77
          Thanks for your help! I tried the trouble reset today but it didn't work.
          I have not found an easy way to open the glass and try to clean. The printer is approximately 2-3 years old.
