Boot up screen
  • XtremeFlyer
    • Sep 2019
    • 2
    [Misc] Boot up screen
    Hi
    Does any one knows how to change the time that the boot up screen shows on Konica minolta models (c224 and onwards)after replace with a custom one?
    I would like to show it during a little bit more time or being able to choose the amout of time.
    I have change it,with the respective boot up screen converter, but it only show on boot for about 2 seconds on c220, c280, c380 these shows for a lot more time on newer machines if you blink it you missed.
    Your help will be much apprettiated.
    Thanks in advance from Portugal
  • tsbservice
    Field tech
    • 8007
    Re: Boot up screen
    No way afaik. Use instead Wallpaper(custom theme) to highlight customers logos etc. A bit awkward as menus hide parts of background but still it's there all the time(except when machine sleeps of course).
    Good luck.
    • XtremeFlyer
      • Sep 2019
      • 2
      Re: Boot up screen
      OK
      Thanks anyway, tought that we can use a DipSW that could affect the time of displaying the boot up screen.
      tsbservice:
      Probably you are mentioning
      [System Settings] - [Custom Display Settings] - [Main Menu Display Settings]
      I also use these one but since I give me the trouble of add a new boot up screen I would like to show it a little bit more time.
      • D_L_P
        Self Employed
        • Oct 2009
        • 1196
        Re: Boot up screen
        When a Bizhub is first setup there's a specific service mode just to set the date/time. Get into service mode then hitting:
        Stop, 1, 1, 4, 4, Clear
        I doubt it but there may be a setting to change the display time in there. Or in service mode level 2.
        Stop, 0, 2
