User Auth - self associating your card
  • rrrohan
    • Sep 2011
    • 1977
    Is it possible for users to assign a card them-self or does the administrator need to do this?
    I see they can change their own password but not assign a card.
    Its for a remote site and the IT guy doesnt want to provide the site users with admin code to copier.
  • ivovb
    • 695
    Re: User Auth - self associating your card
    SafeQ, PaperCut or LK-114?
    BR
    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
    • rrrohan
      • Sep 2011
      • 1977
      BR
      so only way for IT to do this would be to use external server authentication and put the cards ID into AD ?
      I doubt they will pay over a grand in software just for this feature alone
      • B0265
        • Jan 2007
        • 718
        I don't know what model you are working on but check for this setting in the webb interface:
        security - restrict user access - Biometric/IC Card information registration
        • tsbservice
          Field tech
          • 7970
          Can you register them when on site to mount auth. unit and install loadable driver etc.
          • rrrohan
            • Sep 2011
            • 1977
            Winner. thanks
            Notice you also then have to allow Biometric/IC Card Information Registration for each user as it cant be set as a "Default Function Permission"
            its so when new staff need to be setup on copier IT can do this remote and just send provide them with the ability to register their own IC Card as they obviously dont want to need to provide admin password to the copier to do it the traditional way
            • emujo2
              • Mar 2017
              • 1580
              Page Scope Data Admin does a few things with IC cards..
              You can inport a user name/card ID CSV, and if you have one machine setup you can do collective IC card maint. You would need a card reader to give you the card values. E
              • B0265
                • Jan 2007
                • 718
                You also need to install a plugin for the type of card reader you are using to the PS Data Admin.
                • emujo2
                  • Mar 2017
                  • 1580
                  Good info, I have never had to use PSDA for this..I know it can though. E
                  • rrrohan
                    • Sep 2011
                    • 1977
                    you have to use Konica AU devices though dont you. Pretty sure it wont work last time i tried with YSOFT reader
                    • B0265
                      • Jan 2007
                      • 718
                      It has been a while since I done this, but there should be a plugin available for YSoft readers also.
