Upgrading C284e - Require some guidance
  • schmeckles22
    • Jun 2020
    • 34
    Hello,
    I run a printing business on eBay and I currently have a C284e which I bought second hand. I started skeptical with the business and now I have left my job and do it full time.
    Buying these second hand printers has been the worst thing I have ever done but I have been stuck with them while cash flow has been low.
    The C284e constantly has dark streaks down the page after around 2-3 months of use and then I will buy a new one from the company to fix the problem (Possibly cheap drum units).
    I am now in a situation where I can fork out on a new machine, the latest and greatest.
    Which models do you recommend for high quality prints of designs / photos, bare in mind the C284e has been superb for me it's just costing me a fortune to maintain from this dealer.
    What has changed on the new models, do they provide a much higher quality print?
    I appreciate your help, I wish I found this forum sooner.
  • tsbservice
    Field tech
    • 7963
    Re: Upgrading C284e - Require some guidance
    You must quit byuing cheap DR-512 units/chips. Just buy new OEM drum unit and you will forget about it. Also don't go for newer models if you're color picky.
    • schmeckles22
      • Jun 2020
      • 34
      • emujo2
        • Mar 2017
        • 1580
        If you are using your C284e as a production printer I have very little sympathy for you, and I can't offer any sugestions on which OFFICE model would suit your needs..Maybe you can add some details like the avg monthy volume you expect to do.
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          Regards Mark
          • schmeckles22
            • Jun 2020
            • 34
            Yes it sounds crazy, But its business stickers - Not really production, but it does the job and many other sellers in my area use the same printer.
            The quality of prints is suitable for what I need and my customers are happy.
            The low running costs with toner is the benefits.
            I print around 4,000 color sheets a month, it has around 40-50% coverage on average.
            If you know of a low cost per sheet production printer, I am all ears.
            I sort of just fell into this business with little printer knowledge, if anything I hate them! Working in the IT field for many years.
            • schmeckles22
              • Jun 2020
              • 34
              Sorry, New for me, refurbished model from them.
              • emujo2
                • Mar 2017
                • 1580
                I can pretty much guaranty these guys are buying wholesale for just a few bucks each. The wholesaler is not adding 1 part to these before they go out, and the re seller probably fires it up to do a test print, then a light clean..For them they are probably making a killing.
                • tsbservice
                  Field tech
                  • 7963
                  Change your supplier. Get a real tech to see what you're buying and advice.
                  • mga
                    Copier Technician
                    • Dec 2010
                    • 1393
                    Let use know the model number also the machine will not be refurbished as the cost of the parts out costs the machine
                    Regards Mark
                    • schmeckles22
                      • Jun 2020
                      • 34
                      Definitely! I know this, but it was just a situation I fell into.
                      Just require some advise from people who have worked with the machines.
                      • schmeckles22
                        • Jun 2020
                        • 34
                        Model No is Bizhub C284e, the serial number has been scratched off the plate! :O
                        • mga
                          Copier Technician
                          • Dec 2010
                          • 1393
                          So you got a C284e and you are getting the same machine
                          Regards Mark
                          • qbert69
                            • Mar 2013
                            • 1152
                            Sounds like they're ripping you a new asshole on DR-512!!![emoji15]...GBP to USD is $317.50!!! I just checked on Precisionroller.com:
                            DR-512(CMY) = $209.95 = 1 Unit, need 3.
                            DR-512(K) = $93.95 = 1 Unit, need 1.
                            SMDH![emoji57]
                            PS - Shipping not factored in.
                            Sent from my SM-N950U1 using Tapatalk
                            REACH FOR THE STARS!!!
                            Konica Minolta Planetariums!
                            • tsbservice
                              Field tech
                              • 7963
                              Sounds like you're doing some shady business here.
