368 home screen configuration
  • Max
    • Oct 2011
    • 555
    Hi All. I'm trying to get this as my default layout home screen instead of the normal one (please see attached) but I'm unable to find a setting in the control panel options. Found various layouts and buttons association but not this particular one. Can someone point me a the right direction please .
    Thank you
  • Cyclops85
    • Jun 2020
    • 14
    Re: 368 home screen configuration
    [Utility]
    [User Settings]
    [Custom Display Settings]
    [Copier Settings]
    [Default Tab]
    • tsbservice
      Field tech
      • 7983
      You can make this default copy settings:
      Descriptions of Functions / Utility Keys
      To change home screen to copy mode use this:
      • Max
        • Oct 2011
        • 555
        1st thing I tried. Didn't work for some reason. I'll give it a go next time I'm in the office.
        Thank you
        • tsbservice
          Field tech
          • 7983
          Thank you
          NP Max. Wish you good luck and don't forget to give us feedback.
          • CompyTech
            Super Tech
            • Feb 2011
            • 706
            Try: User Settings, Custom Display Settings, Copier Settings, Default Tab set to Quick Copy
            • Max
              • Oct 2011
              • 555
              Will do. Thank you
