minolta di 620
  • cristian
    • 179
    minolta di 620
    please add toner do not want to disapear , after i have replace the cartridge.
    no error codes
    i ve changed the toner motors , both on the tank and the one for the cartridge , nothing.
    i ve changed the tank with another one , nothing.
    i ve disabled the toner empty stop , it has worked untill i have finished the toner from the tank , and then C 0F33 , and C 0F32. I have changed the ATDC , nothing...I have put manually some toner and it has worked untill he have finished it , and the cycle is repeating.
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    Try to vacuum the foam roller in the sub hopper that adds the toner. It can get packed with toner and moisture. Also check the switch in the sub hopper for toner detection.
    • cristian
      • 179
      I have not only check , but replace the whole supply toner mechanism.Nothing yet..
      It must damaged be the board who command the toner motor , or the toner empty stop, because also the toner replenisher do not work.But i don t know wich one is it, and i do not find nothing in the manuals...
      • Darren King
        copiertech
        • 652
        Check to make sure the back cover is on properly. There is a photo sensor that has to be blocked. It is in the lower left corner. If it is not blocked it will show a "Please add toner" message. Ask me how I know. LOL
        Hope this helps
        Darren
        • WaveyDavey
          • Sep 2008
          • 60
          what he said is correct, rear cover interlock not made prevents engine predrive and therefore will not reset toner empty
          • tonerspot
            • Nov 2008
            • 79
            change developer
            • cristian
              • 179
              Thank you all.
              I have put all the screws at the back panel. Nothing...
              What I have done until now:- i have replaced the developing unit with one that works on another machine.Same malfunction , so it is not related to the developing unit.I have replaced the whole mechanism of toner admission, including the motor.Same malfunction.
              What is disturbing is that the TONER REPLENISHER doesn't work , meaning that when i push the button, i hear for two seconds that it starts working but it stops.Also USERS CHOICE does not work.A friend of mine had some years ago the same malfunction , and he said that he solved it by pulling up and restoring all the connectors on an electronic board under the bypass, but it could be a coincidence ...
              • rasman67
                Have you ran an F-8 to set the ATDC back up to a new reference point
                • fixthecopier
                  ALIEN OVERLORD
                  • 4713
                  Does the motor that turns the bottle work? remove the motor, turn the bottle out of position and see if it goes back home when you turn it on.
                  • cristian
                    • 179
                    I have run F8 and then F5 , then i ve cheked the ATDC -indicate 3,2, seems OK.
                    • cristian
                      • 179
                      I have changed allready the motor for the bottle , also the motor M10 at the developing unit.Same malfunction , and of course the bottle does not move....
                      The machine works as long as i put manualy some toner in the developing unit (and if i disable the TONER EMPTY STOP) untill the toner that i have put was consumed.
                      • fixthecopier
                        ALIEN OVERLORD
                        • 4713
                        If this were my problem machine, I would begin to swap boards.
                        • kalindd
                          • Jun 2008
                          • 192
                          Just stop replacing parts.
                          When you open your upper door the one which you need to open to change the toner bottle. Look at the screen , is this indicated? No? Just clean the sensor that is in the upper right corner of this door. Just above the toner bottle. Cheers.
                          • harry2007
                            • 52
                            Change the developer and then run F8. works in 99%.
                            Bafta !
                            http://copierservicereset.com
                            • eg101
                              • Jan 2005
                              • 131
                              3.2 seems really low. I think that model should be over 5.0
