Konica minolta c458 colors trouble
  • fatduke
    • Jun 2020
    • 75
    Good morning everyone,
    I have a big issue with a C458. There is a big problem about colors CMY.
    I changed all the drums chip 'cause them where in a very good state, refurbished CMY Developer, Black changed with a new one, with a good quality powder and reset chip (you know that Km doesn't release them as OEM but specialized companies does), changed transfer belt, transfer roller, clean all the machine from dust and colour powder, checked all the voltage in Service Mode 'bout transfering colours, calibration of image and stabilization, then did a lot of times colour gradations check printed but machine gave all the time poor colours quality only on CMY. I printed the demo page, the one with bird on it, and so, nothing means nothing.
    Everyone of you had a trouble like that?
    I hope is not a faulty MB 'cause I changed everything!
    Thank you in advance!
  • Bix
    • Apr 2018
    • 1421
    Re: Konica minolta c458 colors trouble
    Changing chips on drums doesn't solve the problems. Aesthetically they might seem perfect but it is not so! In series 8 I have few drums capable of making a second life cycle.
    So switch to new OEM drums if you don't want to tribulate quality problems. Otherwise you will spend more time trying to solve a problem that will make you lose a lot of money.
    • fatduke
      • Jun 2020
      • 75
      First thank you for the reply and advice.
      About changing drum chips, I made it a lot of time and only for a second cycle and then replaced with OEM, so maybe now you suggest to replace the DRUMS? CMY ones? Do you think that refurbishing a developer in a professional way could help?
      So I will try to change the CMY drums with OEM ones like always, then I will update the problem.
      I saw that a colleague had a similar trouble but tried to change MC, this is the last and critical solution for this fix if drums will be the same old poor colours result.
      Thank you for now!
      • tsbservice
        Field tech
        • 8020
        Print sample please.
        • fatduke
          • Jun 2020
          • 75
          Hi again
          Attached scanned colour sample (included demo page)c458 P_page-0001.jpgc458 P_page-0002.jpgc458 P_page-0003.jpgc458 P_page-0004.jpgc458 P_page-0005.jpg
          • allan
            RTFM!!
            • 5462
            There is a gap between the drum and mag roller on the one side. Happens when you chop and change units from other models.
            Need to change a part out from the original units to the ones you have installed.
            Had this before but cant remember what needs to be changed out.
            Think it happen when you use K units there is a part on the front side of the drum that is not the same.
            Use the parts from the old units.
            You can install new developer and chip on the dev tanks.
            Whatever
            • fatduke
              • Jun 2020
              • 75
              If could be useful, I replaced the drum unit CMY with a black with colour chip each, because black drum unit had more pages yield instead of colours. Maybe this trick is not useful on C458 series? TY
              • Gift
                • Mar 2011
                • 2459
                Agree it totally looks like there are BK drums in the color slots with "incomplete" modding.
                • fatduke
                  • Jun 2020
                  • 75
                  Gap? Do you mean the plastic piece one that is on the bottom right side that is used to fit the drum inside the machine?
                  Is another machine drum but as you know i removed for perfect fit the drum inside the KM.
                  TY
                  • fatduke
                    • Jun 2020
                    • 75
                    Attached Drum Images
                    • Gift
                      • Mar 2011
                      • 2459
                      Swap the entire end-housing part on the front-end of the unit where the blue handle is located on. Take care to loosen only the necessary screws since some are somewhat factory adjusted.
                      • fatduke
                        • Jun 2020
                        • 75
                        Ok I will replace it with old ones. I think will be really helpful.
                        I will update post later.
                        TY!
                        • fatduke
                          • Jun 2020
                          • 75
                          UPDATE:
                          I replaced the new drums with old ones for a try but results are the same.
                          • jayschrodter
                            • Dec 2012
                            • 36
                            • tsbservice
                              Field tech
                              • 8020
                              Now they changed from factory front housing of new K drums so it can't fit housing from old color drums.
