C454 Cassette Paper Jam
  • fatduke
    • Jun 2020
    • 75
    Hi everyone!
    I would like to share with you this fix for C454 (series)
    I had paper jam from cassette 1. When paper starts its path, paper jam incoming with a little loud noise.
    All stopped.
    I removed 1st paper feed section, looked all the gears, bushes, guides and so on and then I found the problem!
    Attached the pic showing that pointed sensor wasn't in is correct place!
    But this is a fix, a lot of times are paper feed roller, bushes and gears instead, solenoid etc.
    This is only one solution.
    I hope I was helpful!
    Cheers
