C1100. C3103
  • big jase
    • Jul 2008
    • 136
    C1100. C3103
    C1100. C3103 code. 2nd transfer not lifting
    Checked all gears cleaned sensors no joy. Just codes up straight away. Any PPD guys out there who could point me in the right direction
    Was getting C3104 originally cleared that as swing plate was locked
    If at First you don't succeed remove all evidence of ever trying!
  • Bix
    • Apr 2018
    • 1421
    Re: C1100. C3103
    Hi what is the model?
    • big jase
      • Jul 2008
      • 136
      Re: C1100. C3103
      The model is C1100
      • Toxic
        • 690
        Re: C1100. C3103
        Did you try I/O check mode 24-1 - 24-3 ?
        • big jase
          • Jul 2008
          • 136
          Re: C1100. C3103
          Yes but get code on closing doors , get no drive.
          • Toxic
            • 690
            Re: C1100. C3103
            I would first check if drive is not blocked.
            Can you disengage motor from drive (let it rotate freely ) and then try I/O check again.
            Never tried this but it should be possible to do.
            If you get error again i would try replace motor first
            • lucky13
              • May 2008
              • 125
              Re: C1100. C3103
              like what toxic said i/o ps53 24-1 with door open and adu rolled out do not press start button and manually flag ps53 does should show 000 non pressure then flag it and see if goes 001 pressure.
              • khattab.al.masry
                • 212
                Re: C1100. C3103
                Do you hear any noise?
