Konica 8031/Minolta CF2002 IU Chips
  • 700G
    Has anyone tried converting 8031 IU's to run in a CF2002? Can anyone confirm this to be possible?
  • rasman67
    Yes all you need is the bin file and the chip resetter CFR1 software
    • pepper38_cnd
      Field Service Manager
      • Aug 2005
      • 1075
      Ok I got to ask What is CFR1 software? There are lots of software to program these chips and dozens of programmers to do it. Are you suggesting that only that software will make the chip converted? It's a simple chip and easy to program. Just read a chip that is unused and write it to one that is used. Save the file and use it over and over again.
      Now into Ip TV KODI Boxes
      • rasman67
        it's the programmer from Katun, that is just the one that I have. you can change the chips to the proper machine.
