bizhub c351
  • Vesigoth
    • Mar 2008
    • 133
    bizhub c351
    Has anyone had the problem of missing the multipage/single page selection window on the op panel when accessing scan settings/file type? The setting allows you to either scan in individual page/file scans, or single multi page file scans? I suspect a firmware update may be necessary.
    What is the proceedure for upgrading and where can I get firmware for this machine?
    HELLLLLLP!!!
  • dogsbody
    • Jun 2007
    • 289
    Yes, after much heartache found the HDD was unset. Reactivated, formated and haven't heard from it since.
    Cheers.
    The force will be with you always.
    • Vesigoth
      • Mar 2008
      • 133
      Bizhub C351
      Thank you for the quick reply dogsbody. Setting the HDD did the trick. I've been banging my head on this one for a while. Even the IT tech couldn't figure this one out. Thank you again.
      Jim
