BizHub C280 - Problem with downloading logs.
  • snplukas
    • Jul 2025
    When I try to download logs from my BizHub C280 machine using KONICA MINOLTA Data Administrator V4 Log Management Utility, I get the message "The log format is not correct. (9205)". I don't know what is the reason for the inability to download the data. I have four C280 machines and one C250i. The same configuration everywhere, but I can't download them from the two C280 machines.
    Probably the cause of one thing is disk replacement - the only difference I could figure out.
    I checked, among others
    - configurations,
    - ROM versions,
    - Certificates,
    - disk capacity.
    and at the suggestion of a service technician, I turned on the following option, reset the device and turned it on again.
    [Security Settings]> [Security Details]> [Job Log Settings] is set to [No] in the [Administrator Settings] on the Control Panel
    Does anyone have an idea how I can download logs from these two devices?
