Bizhub 600 warming up after 25 mints, Ready to do job so late
  • manzoorwighio
    • Dec 2019
    • 28
    My Bizhub 600 When power on warming up after 25 mints, Ready to do job so late
  • blinxwap
    • Jun 2020
    • 80
    Re: Bizhub 600 warming up after 25 mints, Ready to do job so late
    Replace PCRB
    Sent from my SM-A505F using Tapatalk
    • manzoorwighio
      • Dec 2019
      • 28
      Originally posted by blinxwap
      Replace PCRB
      This Board ?
      • allan
        RTFM!!
        • 5459
        No that is a 5V power supply.
        If the drum or developer is toast it happens.
        But it happens due to a dirty ID sensor more often.
        If you run peculiarity and get errors the machine will keep on trying to get valid data. It just keeps on trying until it times out.
        Also if the ADU latch lever sensor is out of place or the ADU body bent it will do the same. Fusers lamp will not switch on.
        Find out if max density adjustment gives you an error1/2/3 and go from there.
        Whatever
        • blinxwap
          • Jun 2020
          • 80
          [ATTACH=CONFIG]46329[/ATTACH]
          This Board ?
          Nope die green board
          • rrrohan
            • Sep 2011
            • 1977
            ive had single fuser lamps fail causing long delays in warmup since the copier doesnt know a lamp has failed so long as atleast one of them still functions
