Damaged imaging units bizhub c652 series
  • AhmedChamumi
    • May 2016
    • 131
    #16
    Re: Damaged imaging units bizhub c652 series
    Originally posted by femaster
    Does the transfer belt show any signs of problems that line up with the same area on the worn drums? I once had an issue with some kind of buildup on one of the rollers behind the belt. It roughed up the color image unit drum that it came into contact with, causing a similar issue as to what you describe, but there was also some obvious signs on the belt itself that something was wrong.
    Thats really make sense i will try that and get back with findings..
    Regards,
