MINOLTA DI 250
  • vaclav borc
    • Jan 2008
    • 75
    MINOLTA DI 250
    THE LINES AND TEXT WHICH ARE PRINTED, (ALONG THE MOVEMENT OF SCANER) ARE LIKE STAIRS. FEW CENTIMETERS ARE PRINTED STRIGHT AND WELL, THAN FOLLOWS STAIR,AGAIN WELL , STAIR ... THE END OF PAPER IS PRINTED OUT OF PAPER
    EXAMPLE:
    ______________
    _______________
    ___________________
    I CHANGED COMPLETE SCANER BLOCK WITH ANOTHER MACHINE.THE PROBLEM
    WAS GONE FOR ONE WEEK, THAN RETURNED.
    I MEAN CHANGE THE cpu AND POWER SUPPLY? MAY BE ANYONE
    HAD THE SAME PROBLEM.
    wRONG MEMORY?
  • buster68
    • Nov 2008
    • 181
    sounds like the write unit is failing(laser).
    • vaclav borc
      • Jan 2008
      • 75
      when printing self test , it is perfect
      • minimerlin
        • 851
        Check the fibre optic cable is not kinked, also ensure that the ends are clean.
        Please do not PM me without asking first.
        • Hansoon
          • Sep 2007
          • 3383
          Had it several times, defective PWB-HGB board in the scanner unit located in the rear-right corner. Di-250 and Di-350 each have dedicated boards in case you want to swap.
          Hans
          • vaclav borc
            • Jan 2008
            • 75
            Hans
            I CHANGED SCANER UNIT BOTH HGB BOARD, PROBLEM WAS lessen.
            after few days problem returned.
            closer to optical cabel. scaned data are transfered by optical cabels?
            • Hansoon
              • Sep 2007
              • 3383
              Yes the grey "tubing" coming from HGB board going to the main board.
              Hans
              • kink#2
                Try removing rear cover for HGB board make sure nothing push on any of the HGB connectors, make a copy, if its good, re-route all the cable real good before you put the cover back on.
                • vaclav borc
                  • Jan 2008
                  • 75
                  Today, I visited the customer and I replaced MFB board
                  (20 cm x 25 cm vith 2 bateries . Every cables not replaced.
                  When i made first copy , the problem was worst than that.Strong worst.
                  Once again:
                  first MFB board : the image is cuted litle
                  second MFB board: the same problem ,but the image is cuted very strong. is not
                  important notice : second board was not new, I took it of broken machine.
                  The same parts?Diferend problem? Looks like typical defect, typical illnes of this boards.
                  Is not there any calibration, when changing MFB?
                  As for optical cables, I tried to brake it , but reason was - that the machine halted and restarted to service mode.
                  • mitchl
                    • Apr 2007
                    • 501
                    Throw another known working HGB board in the pig, we have seen this problem unfortunately 100 or so times and its always the same deal, the HGB board. I think the same vendor made that POS board as the laser units on these models, hell we wont even cover the laser under contract so many went bad.
                    • vaclav borc
                      • Jan 2008
                      • 75
                      i dont understand clearly. Can you tell me again in easy english.
                      What shoul i replace? HGB board? I changed scaner unit , which includes
                      HGB board. Do you thing there is same problem with another board? So venture?
                      And how to explain, that I replaced MFB board and the intenzity of defect
                      was heavy increased.
                      thanks for any help
                      • vaclav borc
                        • Jan 2008
                        • 75
                        What should i replace? HGB board? I changed scaner unit , which includes
                        Is possible to repair HGB board?
                        thank for any help
