bizhub 282
  • piotrgdy
    • 2
    bizhub 282
    Hi
    I have a bizhub 282, I want to set up sending scans via email.
    In the smtp configuration, I only have a field for the smtp server address and email address,
    no field for smtp password and authentication. In the manual for this device,
    I have read that in order for the password and authentication field to appear, I have to
    set bit 2 and 6 for mode 380 to 1.
    I set Mode 380, bit 00000010 (bit 2) and I get the information: The selected mode cannot be changed.
    software?
    am I doing something wrong?
    can i update the software myself?
  • drowranger
    • Jul 2015
    • 122
    Re: bizhub 282
    typical setting is ..
    SMTP Authentication
    Before starting, make sure NC-4 and SU-2 or SU-3 are installed. ROM version must be current.
    1. Login Admin mode on MFP panel.
    2. Select Admin2.
    3. Open "SoftSW setting" and set "SoftSW 380, Bit6=1 and Bit2=1".
    4. Save Settings.
    5. Open "Network Set" and "SMTP Setting".
    6. Set SMTP Server Address (TCP/IP address of Mail Server).
    7. Set "E-mail Address"
    8. Set "SMTP AUTH User Name"
    9. Set "SMTP AUTH Password"
    10. Save Settings.
    Notes:
    a. If you get error code EA21C6, it means Authentication method error. If you get error code E72217, it means User ID or Password is incorrect.
    With SU-3:
    • If you want to share POP3 User name and password as SMTP Auth User name and Password, set "SoftSW 380, Bit6=1 and Bit2=0".
    • Set the POP3 user name and password on "Network Set" and "POP3 Setting".
    This method will use CRAM-MD5, Login or Plain authentication.
    CAUTION : If you set SoftSW 380, Bit6=1, URL report function with Scan to Server (FTP), HDD will not work.
    ***You wont be able to use authenticated office365 or gmail since this device doesn't support SSL/TSL and AES256 encryption.
    You can use aspmx.l.google.com (74.125.130.27) without authentication but can only send to gmail emails.
    Hope this helps..
    • piotrgdy
      • 2
      Re: bizhub 282
      [QUOTE=drowranger;1542008]typical setting is ..
      SMTP Authentication
      2. Select Admin2.
      4. Save Settings.
      here I get the information: The selected mode cannot be changed.
