Hi guys,
does anyone have any idea how to resolve a C-2214 error code on a Bizhub Pro C1070?
Everything started with a black color shift, a jam and a C-2214 code, I restarted the machine and restarted the printing, two sheets was good then the same problem: Black color shift, jam and C-2214. After that the error code appears on start-up.
I cleaned everything: coronna, gamma plate, drums, belt gears ... In short, everything that is visible. Via the i /o Check mode the 4 front motors are working correctly, so I have dismantled the rear machine and checked the 4 encoders and they look good.
The machine has 1.600,000 prints.
Thanks in advance.
Thanks in advance.
