ERROR C-C186
  • LASSSEN
    • Feb 2016
    • 13
    [Error Code] ERROR C-C186
    Hello,
    i have a machine konica bizhub c452 with error c-c186 after warming up
    searching about this error i realised that firmware is the only solution
    please need help, need the firmware for this model copier
    thank you in advence
    Re: ERROR C-C186
    Originally posted by LASSSEN
    Hello,
    you have been here since 02-22-2106 you seem not to have many posts/comments for that length of time here
    make a small CONTRIBUTION to CTN ( to keep it up n running ) and I'm sure your prayers will be answered.
    ARE you a trained TECH or enduser? we have plenty of newbie techs/enduser's that have BRICKED their units by improper use of Firmware.
    the reason I ask about the TECH thing... your PROFILE is drastically missing key information.. have you EVER been trained on ANY copier/printer?
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1250
      Re: ERROR C-C186
      Hello,
      Firmware should not be attempted if you are not a trained tech. A lot can go wrong. That being said.....they will sell you the firmware for an affordable price at Firmware Update - Printer & Copier Firmware
      I have purchased from that side in the past and can highly recommend it.
      The firmware through them includes the service manual which details step by step how to install it for this model. Do not try and do a firmware update without the manual.
      Also, the firmware data are different between bizhub C652/C552/C452 series and bizhub C652DS/C552DS series. Verify the model number so you can request the correct firmware.
      • LASSSEN
        • Feb 2016
        • 13
        Re: ERROR C-C186
        thank you very much for your advice, I m ready to contribute as well as I can
        I m technician and I had interupted my activity for long time and for reasons that is possible to explain to you
        all,
        regards to u all
        • LASSSEN
          • Feb 2016
          • 13
          Re: ERROR C-C186
          Hello
          problem resolved thank you guys
